Engine Won't Start and I Need Some Help Checking the Igniter.
So my 91 awd died a few days ago after running for a few seconds, and now won't start again. Starter cranks and I hear the fuel pump spin, but I don't seem to be getting a spark. In going through the procedures in the manual for testing the igniter, and everything seems fine until I test for the continuity between the BLU wire and the ground. I've checked the three grounds the manual mentions and they all seem fine, so now I'm trying to trace the BLU wire to the tach, but I don't know where it goes once it enters the wiring loom. Can anyone give me an idea of the path it follows through the engine bay and which connectors I might be able to separate so I can look for breaks?
Thanks for any help.
http://www.civicwagon.com/showthread.php?74-SiWagon-Freebie-Honda-Ignition-Upgrade-D[/h]
