I've blown 3 radiators and running out of options!
It all started last spring. My radiator had begun to leak at the bottom half plastic seam. I chocked it up to being faulty part, as i had replaced the radiator the previous year for the same concern. Unfortunately a couple months later the same thing happened again, leaking from the bottom half of the radiator. Bought a new radiator from a different company and replaced the hoses, and a couple weeks later, same leak, same spot. After some research the only thing that seemed to make sense was a faulty head gasket was letting combustion pressure into the cooling system and causing the seam to burst. So i covered all my bases. I replaced the radiator, new radiator cap, new hoses, new thermostat, new head gasket, had the head milled at a machine shop, and new water pump. Up and running November 17, 2014. Today (January 20, 2015) I go to my car and smell the coolant. Look down and its the same leak in the same spot on the bottom of the new radiator.........
I'm completely stumped at this point. I've worked on cars since i was 15 and today at 25 i'm a Ford Senior Master Tech and a Mazda Senior Certified Tech and have been a full time mechanic for 7 years, but i can't for the life of me understand why after i've replaced EVERYTHING in the cooling system why it's blowing the radiator.
I bought a Honda because in all my years of working on cars i learned that they're simple tough little cars and don't cause too much trouble. I bought a wagon because it was different from the usual crowd and it's 4WD to boot so its perfect on any terrain. I love the car, but it's being quite difficult and i don't see anyone else on this forum having the same problem.
any help would be greatly appreciated! i don't want to give up on it now, but i'm out of ideas
Also look at an all brass radiator. They are about the same price as the aluminum core with plastic end tank units.
I should be able get a gauge on it tomorrow when i get it to the shop, but the radiators blown at this point so its not going to hold pressure and id hate to buy another stock radiator just to watch it break again
http://www.jhpusa.com/store/pc/viewPrd.asp?idproduct=30216&idcategory=99
I think with that at least if you build pressure you'd likely blow out a hose vs the radiator itself, if you're still running stock hoses. Those would likely be cheaper than replacing the radiator if something does go pop.
But it would at least be a crutch so you could see what's going on I think.
checked it this morning, the right side is really pulling down on it hard, i think that might be my issue, gonna order that aluminum one tonight and make sure i fix that mount
Came in the mail today. Looks really good :encouragement:
Nice that it came with their higher pressure cap as well, that's good. Have you done any radiator hose upgrades yet? If not, I've been rocking the mishimoto kit, and it's very very nice. I picked up some german band clamps as well, the ones that aren't cut, all the way through but just have the ridge formed in them, keeps things from biting in to the hose. I prefer them over just the stock squeeze clamps.
Mishimoto MMHOSE-CIV-88BK is the kit, there's also a heater hose that you need as well that's sold separate if you're hooking that up.
MMHOSE-CIV-88HH Black Heater Hose
And the clamps I got were these: http://smile.amazon.com/gp/product/B0036R4UDC/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
For those I ordered three sizes so I'd have enough to cover everything. I think you need 4 of the big ones, 8 of the mediums and 8 of the smalls.
Sorry for the rant, looking forward to seeing the radiator in place as I'm definitely eyeballing these myself.
so after a good long cry in the shower i think i may have a solution...
i think i can simply shave the fan mounts off the bottom half of the radiator giving it enough clearance to go down and seat properly. Due to the size of the radiator i don't think the stock fans are going to fit regardless so i believe there are some slim fans i can get aftermarket that simply mount through the fins? (i'll need to shop around)
tell me what you guys think!
Are those fan mounts on the front side? Mine were mounted to the back. Yeah I'd shave off that widget there at the bottom, the first pic is exactly how my radiator was sitting when I wasn't getting clearance due to the thicker fans.
Yeah based on those pictures, there's not even supposed to be that little mounting bung there. Rat bastards, I'd knock that off for sure, that's likely the majority of the fitment problem right there.
Do you guys have any good recommendations on slim fans?
I'd probably just nab a pair of blox from JHP though. Blox have a 1 year warranty, Mishimoto have a lifetime warranty, though they are about $20 more per.
In other words, fix the actual root cause instead of using an elaborate band-aid approach.
grinded off the bottom tabs, installed slim fans, and she slipped in perfect. Had to improvise on the top rad hold downs but everything went on smooth. Very happy to have my wagon running again especially in this snow storm!
I hate snow.
You may want to shorten your upper radiator hose tho. About 2 inches off the engine end should eliminate the kink.
Unfortunately i lost compression on cylinder 3 about 2 weeks ago. Sold it last night. It was fun while it lasted 😕
