Starter coming on while driving, also tries to start up when parked with no key.
                    Hello, Wanted to ask as there's not much information on google about this happening to Hondas. My '90 Civic Wagon 2WD has started to crank over as I'm driving along, like the key is being turned.. Also if it's parked it'll randomly try to turn itself on (with no key and no one even around it). The starter will crank over until it kills the battery, or in one case it'll actually fire up and sit there idling.
What am I looking at here and what is the most likely culprit?
Ignition switch..
Starter..
Main relay??
Distributor?..
Wiring under the dash or in the bay?
Something generating a signal to tell the starter to turn on... And there's absolutely no remote starter in this car. It's a beater with no mods. And this started happening in heavy downpouring rain.
Ignition switch..
Starter..
Main relay??
Distributor?..
I'd probably start with the ignition as well, since it started after rain I wonder if it's in the engine bay, a short of sorts. I'm curious as to what the problem is. Keep us updated.
It's not a bad idea to replace a 25 year old high mileage ignition switch (currently $26 on rockauto.com), but I don't think it is the source of your issues. There is still the clutch switch (M/T) or the neutral safety switch (A/T) in the circuit to prevent a bad ign switch from doing this.
If your car is manual trans, there is a starter relay in the dash fuse box. That *might* do it.
I think BY FAR the most likely source is the starter solenoid. It's built into the starter, so... You probably need a new starter.
I got a good laugh out of this as well.
Sounds like we got a "modern" day Herbie on our hands...
