Keeps Over Heating when A/C is on!!!!!
So I have done everything in my power with research and also had a mechanic look at it.
New Radiator, new thermostat, new water pump, new belts, new pulleys. My wagon keeps over heating when I run the A/C. Also long as I'm stationary it runs fine. Once I begin to drive it begins to over heat. I turn off the A/C and temperature settles to normal. Yes the fans turn on when its heats up. I have done every search possible and cannot get this thing to stop overheating. This is Florida A/C is a must here. What else am I missing here?
v/r
Manny
v/r
Manny
thanks
Does both fans come on when you turn on the A/C?
Probably not the prob ,but are both fans blowing air inward toward the engine?
