Engine & Drivetrain Quicklinks
Engine Quicklinks
Which D-series can I swap in and keep 4WD?
DOHC ZC into RT4WD
D16Z6 into RT4WD
B-Series into RT4WD (Expanded)
B-Series into RT4WD
Jackson Racking Supercharger Part Numbers and Installation Manual
How to disengage 4WD
How to change transmission & differential fluid
RT4WD Short Shift
Gearing swap in d series trans, rt4wd, and LSD options
Transfer Case Bearings
Viscous Coupler Discussion
Viscous Coupler Solution
Viscous Coupler Rebuild
RT4WD Axles
U-Joint Solution
Rear differential bushing mod
CR-V / RT4WD Drivetrain bushes
Exhaust Quicklinks
Lets see / hear some Exhaust setups!
Any chance these will be linked soon? Looking to reference the "rear differential bushings mod" and can't seem to find it elsewhere. I used hockey pucks on my last wagon bit would like to use the Energy ones this time around. Can anyone help me?
I'll ask Haydz.
Thank you! I called VIP as I live in Portland but they don't have any of them any longer.
I just installed this Energy rear differential bushing kit and it works perfectly. Photos in “rear diff bushing mod” thread.
https://www.energysuspensionparts.com/16.1114
