Broken Front LCA to Frame bolt. Real Options?
Hello Forum,
I have been lurking for a while, but have encountered my first real issues with my 91 RT, so here it goes.
I'm doing a complete suspension overhaul, installing the ES Master Kit, RTA bushings, K-Sport Coilovers and Axis Maglites. Also did a full rebuild on brakes. *Just so those that care have some scope.
I've torn out 3 of 4 LCA's, and am stuck on the last one. I was wrenching on the Front Driver Side LCA last night, and the bolt was frozen, just as with the other 3. I took out the rears using a grinder on one side, breaking the welds of the thread-nut on the other. The pass side came out with PB Blaster and breaker bar (lucky). Actual question: I broke the head off of the far bolt that attaches the front LCA to the frame. I ended up with the bolt head and 1/2 inch of stud in my hand, and the rest of the bolt still frozen in place. Has anyone addressed this before? My grinder doesn't fit in either side of the bushing sleeve space, and PB Blaster isn't doing anything. Need some GURU advice.
Thanks,
Ilya
Thanks,
Ilya
-Ilya
Hope that made sense, and thanks for the replies.
