Clutch Cable Fully adjusted, Clutch Barely Engages
Hello everyone,
I have a problem with my clutch pedal/clutch cable. A few months ago I thought my throw out bearing went out because the clutch pedal wouldn't come off the floor. Before I checked anything like a normal person I changed the throw out bearing and put a different trans on. Come to find out the problem the whole time was the clutch cable because after I changed that everything worked "fine".
The clutch will not grab unless the cable is damn near all the way fully adjusted. AT this point it has worked for the past month or so no problems but now every time I put the clutch in I can hear a creeking noise coming either from the cable or the pedal assembly.
What I am missing here? I looked at the pedals and nothing is broken... yet.
If I was you I'd pull it and reinforce it so you know it'll never be a problem. It's difficult to see unless you're really underneath.
Charb, do you have an image of what a failed wagon pedal assembly looks like?
Is it something that we can examine (visually) without pulling bits off the car?
Also from what I have read, in order to reinforce the pedal assembly wouldn't I need to take the dashboard out?
To reinforce the pedal assembly you don't need to take out the dash.
It's a frustrating job. Angled pliers, swivel wratchet, time. My hands looked like i stuck them in a barbed wire fence.
If the pedal box is flexing to the left side as you clutch (which is what happens), imagine the loss of cable tension that is happening as it's flexing.
When I adjusted my clutch cable on my old D16 wagon, I to had to adjust the cable ALL THE WAY TIGHT, as tight as it would go.
You need to verify
when my current pedal box goes, it will be my 3rd box. I had a reinforced one, but it got crushed when the wrecker crushed my car before i could get it out! ass.
- flashlight
- push clutch all the way to the floor
- if the clutch pedal is swinging out to the left AT ALL, it's starting to go bad
- look right at the top where the clutch pedal mounts, there is a pivot rod, that's where mine have broken. one even totally cracked almost in half down the entire box.
youve gone to all this trouble yet you won't pull the damn assembly
The box needs to be removed, and some welding needs to happen. Or better yet, find a wrecker with a box, get it, reinforce it, no down time other than install.
And Courtney, I have two wagons pal
I bought my 5speed for almost nothing because 'it needs a clutch'. Of course it was a pedal assembly like usual... at least I listened to wise words of others and it was pulled and fixed in less than an hour.
sometimes it takes just sitting there and figuring things out on your own where you can come up with own conclusions if you dont think the advice your getting is correct. just sayin
So you pulled your dash out, fixed your pedal assembly, then put your dash back in, in less then an hour? Now I am confused. haha. IDk I just have never talked a dash before but that seems to be the only fix as of now. Oh well I appreciate your input, now time to figure out what my plan of attack is.
matbe pull your seat to give yourself some space to lay down. Definitely don't pull your dash.
the red dots are bolts that need removing. and of course all the cables connected to each pedal.
Everything seems to be intact. What's the deal? I've got roughly 320,000 miles on this guy, I'm suspecting it may have been replaced already. I've read elsewhere that someone installed a 91 CRX assembly? I'll get pictures soon.
Since it's out I feel I may as well reinforce it, I just need to know where. I found a thread but links no longer work and pictures are no longer available! Thanks
I can't remember what the stamp was, I believe it was SH5. It does kinda look like there's been some work done in the area that typically breaks.
Well it was a pain in the butt to do but I at least fully understand what to look for and I have an idea on why it would break. I also lubed up the clutch cable and clutch pedal meeting points, as well as the cable/transmission lever thingamabob.
Clutch is much smoother overall but I still have a point towards the end if the clutch pedal's range of motion, where it just clunks. So I'm suspecting it's the clutch and I'll deal with it later, not in the mood for that heavy of work at this point. Haha
However, the "clunk" or "dip" or whatever you want to call it, during the clutch pedal's travel is gone. I just drove to work one morning and realized that the pedal is as smooth as my other hydraulic operated clutch pedaled vehicles I own. I thought maybe because it was warmer out or something, I dunno, but nope, a week later still working perfect. Just thought I'd share.
I have one that someone other than me brazed with the bushings in place....
Oooo what's that smell?
