Smic vs fmic snail heads chime in!
I'm looking to embark on my first turbo build it's not going to be any thing serious just want a little more power. It's going to be on a sohc zc with no mods , the motor has got maybe 10k miles on it since I swapped it and when I got it , the motor was still silver on the inside so i assume the mileage is very low . So my question is on a light psi turbo build does smic make a big difference compared to Fmic I got a little vent cutout in my hood I think it's be a prime location for a smic but am curious if I'd be cutting my self shorter than I am already with a low psi turbo.
also curious as to what trim turbo would be best for either low or top end I have looked at turbo builds but not a lot of info can be obtained from a lot of the threads I checked out .
i want to plan for a high end and a low end power so I can research the pros and cons a little more in depth
For a D series, if it it stock and you intend on keeping it so, ~200-220 is usually a solid power goal and keeping everything stock. A lot of D guys run T25's because they're cheap, spool very quickly and hold decently under low boost through the power band. If you are trying to make it cheap, but reliable, http://www.homemadeturbo.com/ is an awesome resource for info. Dseries.org will also have a lot of info.
If it were me boosting, and wanted to stay quality yet reliable, go-autoworks.com is where I would buy my kit from. VERY comprehensive and the owner if a D series guy. They have a street kit for $2k that has solid upgrade options. I would upgrade to the GT28 and enjoy the ability to upgrade the motor and not have to touch the kit at all. Good luck man!
thats the hood vent i got right now i plan on fabricating a cal induction type scoop for it and prop the hood in the back a little too
i also heard you get quicker spools and more low end power with smic since its closer you have less piping and there fore less time to charge.
and yea i think a little hole in the bumper with a tube directing air up to it would be a idea as well.
i think a smic placed right there would be perfect like this guys
my motor is a sohc ZC as mentioned in op, my goals are in the 200whp range just a reliable daily setup help me get on the fwy and have a little fun on there as well.
I like to go on spirited drives through the turns and intend on tracking my car at events sometimes so i want the power low to mid range so im able to use it when powering thru turns instead of it being a surprise mid turn when reaching high rpms so it cant cut out at high either ( idk if im making sense any more )
i did some research on that homemadeturbo website and came up with a parts list im looking for a cheap piece together build right now im lookin to buy mostly parts used.
im thinking a td04/05 from wrx or t25 i dont know much about the trim sizes and what means what with all that so im just going off of others builds that are aimed at the power i want .
i just read that smic are better for lower power builds and to go fmic when your lookin for like 350+ or something like that.
Have you ever thought of the water cooled intercoolers? They are a bit more in terms of price but this might help out if you are concerned about heat issues or location.
Air to water intercoolers are more efficient for straight line car that isn't a daily. The efficiency is substantially better for short periods but the heat soak is worse than an air to air intercooler. I have done a lot of reading on them lol.
i can dig it thats my issue i just belive that dseries arent all that to the point you can say it needs a fmic , i mean if all these other cars have smic stock and they weigh more and have just slightly bigger motors theres no reason a car like the wagon cant preform using the same layout
Internal wastegates are okay, but are limiting the power capability. External gates can have their springs swapped to adjust boost ranges. Given what you want to do, and that it is your first time, an internally gated T25 would work just fine.
To counter your "need for a FMIC" statement, there is no need for an intercooler at all. The concept of a turbo will work all the same. The efficiency, however, will be way less due to the AIT's being pumped into the motor from an exhausted heated turbo. That being said, the SMIC will work okay because it will still allow surface area for heat exchange, but not as well as a FMIC.
For it being your first time boosting, keep it simple. What I would do if I were you, is buy the entire turbo set-up as a kit. Buy the Go-Auto street kit, and upgrade it to the GT28 ball bearing. Contact Greg at Go-Auto and tell him your set-up and vehicle and he will make it happen. From there, look into tuning, fuel, clutch and axles. You're overthinking everything and wanting to be unique by a lot too much for a first time boost lol.
can i reroute the wiper water pump to spray water on the intercooler to prevent heat soak?
Garrett GT1752
comes off a saab 9-5 theres one at a local pick and pull im thinking the turbo can be had for cheap but im not sure if this would satisfy the desired goals with my build
Why would you ever WANT less efficiency than you can have? Price won't be much different, so why bother?
thanks i thought that was pretty smart too but know nothing about turbos
but it wouldnt be nothin to wire up a new button and motor specifically for that or a seperate resiviour all together
That said, that's a lot of what they're factory engineered for. So that motor design might work with that a little better. Though I do love that pic you posted showing the side mount there. That looks like a perfect spot for it, almost so much that I'd be tempted to scrap my own plans for a rear mount turbo.
thats some good info to know tho . i look at it like electricity (air flow) longer the piping or wire more you lose
Where it's sitting, you could even go as far as building some custom housing around it, with some aluminized insulation on it to help reflect engine bay heat away from it. Could be fun
If you do it, document the process this type of stuff is fun.
