Mysterious shifting issues after lots of work?!?! New clutch kit, cable, fork, etc.
Hey all!
I'm at the end of my rope. I love my 91 RT4WD but we can't figure out WTF is up with the transmission. Here's what happens - When cold, it shifts fine. After fully warming up, shifting into first and second requires extra force and while the pedal is fully depressed. Even third can be sticky when its hot.
Here's what we've had done at this point -
New clutch kit + cable installed after the pedal started just going to the floor one day. This didn't fix the problem. The shop I had it at refused to acknowledge that it wasn't right for the clutch to go all the way to the ground for the clutch to release. Stupid, I know.
I have my trustworthy ASE mechanic buddy help me out, and he adjusts the cable to max so I can actually shift decently. This works for a few days, and then degenerates into the same situation of sticky shifting.
We drive it for a bit like that, shutting it down at red lights to shift into first, until we have the $$ to fix it.
I take it to my ASE buddy, he pulls the transmission and replaces the release fork, as the old one was worn down a good deal. Everything else looks pretty good according to him. He slaps it back together with a new clutch cable. We drive it for a few days and its great, but now its slowly getting sticky!!!
Any ideas???
Any ideas???
Also check your pedal assembly
When you say "bind up" do you mean getting stuck on something? I don't think that's the case.
Is there a specific part to look at on the clutch pedal assembly where I could see bending or cracking?
Thanks much for all the suggestions!!
This morning it went into gear with no problem, then by the time I got to work it was almost impossible to get into first. Once I'm moving it shifts alright but from a stop, at its worse it won't go into any forward gear at all and will grind like crazy trying to go into reverse.
The clutch cable isn't going to shrink and stretch so much that it would cause these issues. Is the engagement point in the pedal moving further toward the firewall as the problem becomes more prevalent?
Are you getting the proper amount of movement out of the clutch lever coming out of the transmission? Does the pedal feel like it gets harder to push as it gets closer to the firewall?
Are you guys using the right gearbox oil? Try using 10w-30 or 10w-40 engine oil in your gearbox.
If your able to select gears while its cold and not when warm it would make sense that the oil viscosity is wrong when warm.
Honda used to use engine oil rebadged as gearbox oil back in the times our cars were made. My gearbox loves it
