I keep destroying oil pans -__-
Does anyone have a way to be dumb low and not blow out oil pans? the car has a b series in apparently they hang down lower. This is my 2nd one in 4 days :apologetic:. I have seen that VW guys do a thing called "Pan Armor" where they weld steel on to the bottom of the oil pan im going to try that out this go around and see if it will work. My other idea is to raise the motor but i have no clue on how to go about doing that. to give you a idea this is how the car sits.
Just have to make a bash guard or raise the car
Raise the car. If it's to the point where you are blowing oil pans frequently, you're too low
Search for pics of Rally cars, see what under body protection they have. Copy it as best you can
This is about as low as i can go and not break things ( for the last few weeks) i put a new motor mount in, Put a motorso 5.5 qt oil pan on (hangs lower but is made stronger) and raised the car up just a hair she seems to be good
for your problem i would suggest a skid plate. what wheels are those and whats the specs of them your wagon looks good
EDIT: Don't quote images from the same thread.
I think I got an idea, since I own an evo that has a huge underguard that goes over the front bumper and underneath the car.
If you could make something similar then you could forget the worries of damaging your front bumper, engine and anything under the front of the car.
Mine is made of kevlar and is just huge, I need two people to carry it. Here are pics to give you an idea:
Mine is like in the last pic only black, and it goes over the front of the bumper, with that I can go slide on the curbs with the front of the car. The thing is so sturdy it saves my bumper all the time. And oh going over the bumps I always hear them rub against my shield.
Hope this helps, and you ought to go visit a rally shop nearby!
