A/T transmission radiator, as motor oil cooler?
So to further my confusion regarding my car and some of the comments about was it originally automatic, even though the VIN says it's not. It seems to have an automatic transmission radiator in it. At least I think, please correct me if I'm just mistaken.
I have two ports at the bottom of the radiator that you could connect hoses to. I know this is how a lot of automatic transmissions have their fluid cooled, but I'm not certain if these had a separate cooler and this is just a radiator from a later model civic or what.
Either way, my inquiry here is would it be feasible to get one of those oil filter blocks that lets you run a remote cooler and just use the automatic transmission ports to cool the motor oil? I can't think that the detergent packs in the oil would have any real adverse affects on the radiator. I'm not sure about the temps though, if an automatic transmission runs much cooler than motor oil and that heat would cause a problem.
So just putting this out there to see what you all think or if somethings been done like this already and I just missed it when I searched. I did find a humorous thread that Charb locked due to getting a migraine reading it =D
Thanks. I'll hook that up sometime in the near future and keep my fingers crossed. I wouldn't see too much difference running that through there vs a separate oil cooler, in fact my old volvo has a cooler that works in a similar fashion. It's a sandwich that passes coolant through it in one set of the passages and then the oil through another. A heat exchanger as it were.
