Turn key to "start", but *nothing*! Not even clicking...
My car sat for a few months, and when I went to start it... nothing happened. Everything seems normal in "ACC" or "IGN" positions, but all I hear in "START" is the fuel pump. The battery voltage is fine, so I'm not sure where to look next. Any suggestions?
When you turn the key to start, do the dash lights dim but stay on or do all the lights shut off?
Have you had the battery tested?
Should be simple troubleshooting and the above is where to start.
http://sailsplendidisolation.blogspot.com/
They started in California and are currently in Texas, living aboard and cruising on their Cal 28.
