miricale x bar , X stablization bars. anyone got one? which ones fit our wagons?
http://www.evasivemotorsports.com/mm5/merchant.mvc?Screen=PROD&Product_Code=EMRACING-AXI-CRX
as i recall normal strut bars for the rear for "ef" chassis dont work with our wagons because the distance btwn the struts are different a little wider i believe...
considering the shape of the wagon i think its evident the rear end could use some support most of us have issues with the roof popping and stuff which i thnk is obviously a problem with rigidity in the rear end.
i had a c pillar bar in my old wagon and i think it helped a little bit but i think the " X " style braces are the ones that really enhance rigidity if any of them
so the question is , whos got one? which kits would work?
im curious if the DA model would be the proper choice as they are a little wider bodies...
yeah your probably right..
I haven't run one but a guy near me is a vendor for PLM and their X Bar seemed pretty solid and heavy duty. Adjustable ends all around. Might be worth it for the wagon.
