4wd system
Hey guys,
So I been having some problems with the rear diff and mounts, its been making all kinds of noises when going in reverse and it vibrates from 30-50mph.
I filled my rear diff mount and added the coilover bump mounts to the rear diff to keep it from moving. It helped with the big "thug" noise.
I looked at my drive shaft and it looks like the rear U joints are worn out and they have some play, so I decided to remove the 4wd system while I fix it, since the wagon is my daily I cannot afford to have it down for too long.
I came across a problem I cannot remove the rear axles, I currently having them hanging with the axle nut off but I cannot remove them.
I was reading that I need to have them pressed out, is there another way around this? Can i just rip the boot and remove the axle by leaving the outer part of the axle still in place?
Thanks
Thanks
More pictures here:
http://imgur.com/a/uMvzt
These are the rear ones... I have them hanging at the moment bc I cannot remove them from the trailing arm
I tried hammering the axle but it doesn't move, I was reading online and theres people that say they need to be pressed out or something like that, but this does not make sense because this would not be practical.
Does any one know if the axle can just be hammered out or do I have to press them out?
I don't want to continue hammering if the axle needs to be pressed out, if this is the case I think I can just remove the boot and pull the axle out without removing the outer cv part of the axle. I can just leave the outer part of the axle on the trailing arm.
What do you guys suggest I do?
Thanks for the suggestion, I will rent that tool tomorrow and try that out.
I was able to get the axles out. The passenger was easy with the 3 jaw puller. The driver side was a different story. I broke trying to get the axle out. I ended up buying a sledge hammer and using a big punch I was able to hammer it out. I also used the penetrating oil in the process.
Also use some anti seize grease when refitting
yes it did, after taking everything of I notice that the U joint near the rear diff was shot. The ends had play, so what was happening was that the part that the U joint holds at the end of the drive shaft was rubbing with the drive shaft.
I will try and post some pics for u.
I believe that this happened because I removed the rear axles and just let the hub open. Meaning there was no axle with axle nut holding the hub a wheel bearing.
Let me know if that was the cause of the wheel bearing failing?
So what I did after it was too late was I bought a bolt, two washers and nut to simulate a axle and nut in the rear hub. Meaning that the bolt and the two washers help sandwich the hub and wheel bearing.
Has anyone had this problem with the rear wheel bearings going out after removing the 4wd system and leaving the rear hub open like I did in the beginning?
Thanks guys
Thank you. That would be helpful. What did the reverse sound like with the damaged U joint?
So after removing the rear diff and axles my rear wheel bearings gave out. There is a lot of play. Do all civic wagon rear bearings the same or do I have to get rt4wd. Does anyone have a part number for it? Also to avoid from future rear wheel bearings going out what do you guys do when the rear axles are remove from the hub? ( I remove the 4wd system because of bad u-joint) I tried using a bolt and washers to hold the hub and wheel bearing in place but did not help, any recommendations?
To remove the rear wheel bearing from my rt wagon I must get it press out right? Has anyone done a rear wheel bearing on a rt model wagon? any suggestions?
Back side:
Front side:
Video of the wheel bearings:
http://vid149.photobucket.com/albums/s54/keller-101/VID_20140804_190705_5781.mp4
http://vid149.photobucket.com/albums/s54/keller-101/VID_20140804_190645_1951.mp4
I found the problem to be a worn out u-joint. I was able to take my axles of and everything. The problem now is that My rear wheel bearings went out causing the rear hub to move dangerously. If you look at the two videos I posted the bearings sound nasty and the moves a lot. It has play in the hub.
I want to know if I need to replace just the bearing or hub and bearing? And do I have to get the bearing press out?
After replacing the bearing what are my options so that this doesn't happen again? I do not have the rear axles installed because I removed the 4wd system. This means I dont have the rear axle holding the hub and bearing in place. What do you guys recommend I do?
Yes, I believe the bearings would be best changed with a press.
What I notice when I removed the rear axles is that the the outer cv part of the axle does not want to come off the shaft. Even after removing the outer cv boot. I will try and post some pictures.
That was the reason I tried using a nut, bolt, and washers.
Unfortunately I had to sell my wagon a month or two after replacing the bearings so im not sure how the replacements held but they are out there. You have to do some searching.
What do you guys recommend I use or do? Would a bolt, nut and two big washers work in place of the axles?
