Trailing arm clearance issue
I took my rear trailing arms off to have the wheel bearings and bushings done. I'm trying to bolt it back up and this is what I'm looking at. I feel like the bushing is positioned incorrectly and I'm not able to bolt the toe links in. What do you think?
  • bkmc24bkmc24 Senior Wagonist
    The rod that goes through the trailing arm bushing is tapered a specific way. It might be backwards. I want to say the longer end goes inward.
  • Disregard got it. Didn't realize how easy the bushing bar? slid through the bushing. Just had to hammer it loose and wiggle it.
