Rear Hubs on 1988 RT4WD removal tips
Anyone have any removal tips for the rear hubs on a 1988 RT4WD model? Having a hard time getting them off the car.
Do you have to take off the trailing arm to remove the hub? Tried a 3 gear puller but pressing on the rear CV joint that hard seems like it will damage the CV or the rear transmission.
I am guessing this question is in the correct sub since it involves the rear drive axels.
http://imgur.com/a/Vv078
You can see part of the bearing still on the hub. I think that is called the "race?" Then you can see some of the bearing under the clip, then another unit below that.
I have to take apart the other unit, clean it up, and get the other race off the hub.
It is strange what little bit really holds on a wheel to the car.
