car wont start
my 89 honda civic dx will not start
i have added fuel, oil new battery and new starter still nothing. any suggestions?
well first off are you getting spark? are you getting fuel?
if you arent getting spark it could be:
a.) main relay
b.) distibutor (or perhaps just the cap and rotor, also check spark plugs and wires)
c.) grounds
if you arent getting fuel check:
a.) MAIN RELAY, quite possible the #1 reason many older Hondas wont start. it controls the fuel pump prime, when you put the key to the "ON" position you should here a click and the fuel pump prime. listen for this click sound from under the dash, it usually clicks after the check engine light goes out. also listen for the fuel pump. NOW, if you here the clicking but no fuel pump it could be:
b.) bad fuel pump.
