Rear Archs/ Fenders Repairs - how have you done yours?
My shuttle is booked into the bodyshop this weekend to save it from the scrap head.
They have asked me to supply the rear Arches / Fenders repair panels for the job.
Im looking for people opinions on what you have used?
http://www.civicwagon.com/showthread.php?18104-Project-Beater-%28UK-Build%29&p=215665#post215665
good job on yours though man!
http://www.fixmyrust.com/index.php
Both sides for $37.44 plus shipping
does the trim piece that goes by the door handle fit? by this picture it looks to be too thin....
Using Hatch or Sedan panels is your best bet
1: the tires will not be centred in the wheel well because of the narrowness of the sedan arches near the rear door
2 :the OEM wagon beltline moulding can not be used .
3 :the rocker cover ends up with a gap because it becomes a bit too long .
I do not find anything that terrible about all of this . I hope to figure out a way to shorten the trailing arm to get the wheel centred sometime .The only way to repair the rear wheel arch rust is with new sheet metal welded in .Bondo or fibreglass fixes do not last long. I also bought a set of hatchback panels because they might be able to be adapted better than the sedan arches .But I have not played with them much .I just thought I would get them while they are still available .
Has anyone tried to use HB panels instead of sedan ones?
EDIT: I can answer my own question. I found images of HB and sedan panels and realised that the HB panels don't have lines for the doors like sedan and shuttle panels do:
