LF inner cv joint breaking
I've seen this in a few threads but mine is a little different. Anytime I have the steering wheel locked to the left the inner joint seperates. It's as if the joint is being pulled apart. I've been through 5 napa axles. It looks like the wheels have a very wide turning radius, is that normal in the wagons? Is it possible that the napa axles are too short? It's a 2wd 91 stock engine and it's not lowered. No front end parts have any play in them. I'm stumped. Thanks for any input and sorry for the book.
Some axles have shorter CV joint inner housings. I tried an oreilly new unit and it was about 1/2 inch shorter than one from autozone. The total length of the cv axle was the same but the inner joint housing was shorter. When turning all the way the joint would pop out with the shorter Oreilly part.
