91 wagon b17a1 turbo build
Im building my b17 for boost this go around
Let me know wgt u guys think qbout wht im doing so far
B17a1 block
B18c1 main girdle system
Arp mainstuds
Arp rod bolts
82mm wiseco forged 9.2:1
Block guard
Cometic head gasket
B16b ctr head with supertech valve springs and retainers
Stock ctr cams
Skunktwo pro series intake mani
70mm s2 throttle body
Last build was on10psi on neptune and was a stock engine
Im thinking this setup should hold 15 if not more
Wht kinda if power numbers shoukd i exspect from this setup?
Thanks in advance
B17a1 block
Arp mainstuds
Arp rod bolts
Block guard
Cometic head gasket
Stock ctr cams
Thanks in advance
I would Also advise against against the blockgaurd. they tend to exert unequal pressure on the cylinder walls doing more harm than good honestly.
