rt4wd input shaft seal and bearing part numbers
Car: 89 civic rtx
Motor:D15b4
Problem: screeching clutch.
First occurred: after sitting dry stored for 2 weeks.
Clutch thrust bearing noisy, just as cheap to get a whole clutch kit, previous owner noted input shaft worn and seal leaking, going to fix it all at once.
About to change the clutch in a 89 rt wagon, called up honda to get some part numbers for the input shaft seal and input shaft bearing and got these
Input shaft seal: 91206pc8005
Input shaft bearing: 91004pg1880
The shaft seal comes up as a acura seal and the bearing doesn't come up on Google either.
Honda said the bearing is a consolidation part meaning it has to be specially made :(
Have any of you got correct part numbers for the parts needed?
Thanks for looking
