Going D15B2 to D16Y7 Sensors help!
I am using my dpfi harness from D15B2 and confused on where the temp fan swith and oil pressure sensors from the D15B2 bolt up to, on the D16Y7. Both sensors reading the coolant match up on the side of the head of the y7 but I am stuck on where the temp fan switch goes and oil pressure goes because they do not thread in from the b2. Can someone help me out on his issue that I am confused on? Thank you.
  • the oil pressure switch should be in the same spot on both motors (right above the oil filter). the fan switch on the d15b2 was also on the back of the block. but the fan switch on the d16y7 is on the thermostat housing, which has a different plug than the obd0 d15b2 fan switch, so you would have to change the plug on your original harness.
