toggle menu
civicwagon.com
civicwagon.com
Sign In
Register
Sign In
Register
Sign In
Register
Home
Engine & Drivetrain
what (4WD)clutch.....(Solved)
topshatta
Band Wagon
February 2008
in
Engine & Drivetrain
what clutch and flywheel setup and i use on my 4wd wagon with a 95 single swap?
curt
Wagonist
February 2008
stock 4wd clutch, flywheel and trans
nominous
familEE
February 2008
Later D series flywheels will work correctly yeah ?
So long as spline count is the same ie: younger than 88 model tranny.
Sign In
or
Register
to comment.
