Oil Leak underneath intake manifold Help
I found oil leak underneath intake manifold on passenger side but I am not sure if gasket is bad or pcv bad or rear main seal. I replaced dizzy o ring.
Currently, I experience bad fuel milege, engine vibration and fuel leak from injector o rings.
Any one help me?
Thanks
Any one help me?
Thanks
Oil leak 's probably from head gasket.Not a prob unless it's a lot.What I've heard peeps do is to clean it up & silicone it.An idea I had is to silicone it.Let it dry & retorque the heads when I do a valve adjustment.
Did you scrape the white corrosion off the dizzy cap points?This causes lite vibration probs.
I scraped the corrosion on the rotor but did not on cap point. I gonna clean cap point soon. Thanks
