rack & pinion???
I have 2 questions about the rack & pinion if anybody can help me. My wagons is going bad and I wanted to know if a sedans rack will work and also mine doesnt have power steering so would i be able to put one that has the system and not use it???
    Get a civic/CRX Si one. Better ratio.
    As far as the sedan, I have no idea but imagine it would. The front ends on 88-91 civics are pretty much identical.
    You can just loop the lines on the sedan one if you go that route. I'd still get a CRX/Civic Si one!
    A power steering rack won't fit unless you change the whole crossmember.
  • JVracerJVracer New Wagonist
    wow I didnt think i would have to do all that I guess am going to have to start looking for a one online
  • 90 RT4WD (Cody)90 RT4WD (Cody) Senior Wagonist
    All civic's use the same rack, I have a CRX si rack in my wagon, love it!
    so do you have to change the crossmember or not
  • XdmonXXdmonX Band Wagon
    JVracer wrote: »
    Not if you get a manual rack, but you would if you get a power rack.
    ok now am getting to understand
  • DomoHondaDomoHonda New Wagonist
    Just swapped a new rack in my 91 2wd with ps. Jv, I'd listen to these guys tho, go crx all the way. If you need help changing it out pm me.
  • I have a B-series in my wagon. Anyone have a B in theirs that tried to take the rack and pinion out without dropping the crossmember?
