Dx / 4wd seats in wagovan
I searched but couldn't find a hie to or any specific info. I bought an 89 wagovan and my buddy gave me a set of dx seats the fronts swaped right over no problem. The rears not so much. Do I need to cut the brackets out of the dx and weld them in. Any info would be great thanks guys. Pic would be awsome if someone has done this.
The short answer is yes. You will need to swap the brackets to do it right.
first you need remove the hinges that flip up the seatback
One is a 12mm bolt and the other apears to be impossible to remove. I just used an agle grinder to cut a slot in to it then unsrewed it with a flat head. I'm sure they won't all be that easy
Here is where you you meed to weld it in. Clean the area and weld it in
Ok last big thing. The brackets that hold the seat bottom in. The wagovan seat only has two brackets the dx has three. The two on the outside almost line up perfectly the will bolt right in. There is not a hole to bolt the center bracket in, so you need to either weld in a nut somehow or put in a self tapping metal screw. I haven't done anything yet. Here is a pic
