toggle menu
civicwagon.com
civicwagon.com
Sign In
Register
Sign In
Register
Sign In
Register
Home
Engine & Drivetrain
88 rt trans speed sensor replacement
Freek
Wagonist
September 2013
in
Engine & Drivetrain
Has anyone tackled this mine other trans deicded to have diff explode . My backup 8 trans speed sensor is broke off where the clip is needed to hold the cable in.
bam-bam
Council Member
September 2013
Soak it with some good penetrating oil, try to twist it back and forth. It's probably corroded, but only down to the o-ring.
Sign In
or
Register
to comment.
