4WD Rear wheel bearing seal part number?
I took apart the rear wheel hub to fix a noisy wheel bearing. Timken part number set35.
There is a seal for the bearing but local auto part stores do not list one. The Fwd rear wheel bearing seal wont fit. Its too small diameter. (Timken 473367)
Anyone have a source for rear wheel bearing seals?
Thanks
  • swaggyswaggy Band Wagon
    so i think i got it worked out. there is no seal on the 4wd model. it uses a B35 sealed bearing. the seal that i had was part of the factory bearing that i pulled out. :hopelessness:
    but its all good now. time for a new radio and idle air control valve :encouragement:
