possible fuel problems
Okay I got odd issue rt started up drove fine parked it with 20 min start up n died right way I didn't hear fuel pump turn on so I swap out the pump still nothing
Had the car towed home n started up n drove fine again then I got some new rims jacked the car up put the rims on n was gonna go on joy ride but car started n die
right way again so I switch fuel pump again n nothing happen so I try to start few times day for week n to day it started right up but I don't want to drive cause I know it gonna happen again. Does any one any idea on what it could be
http://www.civicwagon.com/showthread.php?74-SiWagon-Freebie-Honda-Ignition-Upgrade-D&highlight=ignition+upgrade
They should make this a sticky it happens enough times.
