Fog light wirimg help
I searched but didn't find much. So I got this switch from a fellow member and it looks like its a rear fog light switch. I was also told that the wiring could be the same as a defrost switch. My question is which wires would go to my power source (Im Going to use a add a circuit), ground (which should be the black one), and to my relay. Here are some pics.
If this helps ill tell you the colors from left to right, top row to bottom row. ( they all have little grey dots on the wire)
black
Black with yellow stripes
red
black with green stripes
red with black stripes
Thanks!
black
red
Thanks!
man Im really drawing a blank
red/black = unused (i dont think I wired anything to this.)
green/black= power in?
yellow/black= power out?
black= ground
red= ??? unused??? (you would think its power, but i cant remember lols)
Im not sure now- that may not be right? lols glad I could help...
I will check my wagon and get back to you... wire like this with Relay
Ok sorry it took me so long- but I really only cruise in the wagon on my days off... Anyways I was right
black= ground
red= unused
red/black = unused
Those red wires I believe have something to do with lighting up the switch itsself as there are 2 bulbs in the switch. One comes on when it the button is pressed. The other should come on with the Dash lights- I have not figured out where to wire them to the dash lights.
green/black= unused
black= power in
red= unused
red/black = unused
So my advice to anyone who wants to do this is to try wiring it up both Bill's and my way and see what works and post here for your results because I'm curious.
