1991 wagon 4wd manual which distributor?
i looked into a reference book and i was not sure if i selected the correct car but two came out of the oem parts number.
do you guys know which distributor part number i need and whats the difference?
must fit 1991 civic wagon 4wd manual 6spd
civic distributor whole assembly unit.
which unit?
TD-18U
or
TD-01U
which unit?
TD-18U
or
TD-01U
all of those are already MPFI, Silly Ashby
the TD-18U is for 90-91 mpfi cars
the TD-02U is for 88-89 mpfi cars
You can pretty much ignore the two different part numbers for mpfi cars. They are interchangable. Many times, you will see the TD-18U listed for all years 88-91 mpfi cars.
