Alignment specs after DA big brakes. PICS
NOTE: Skunk2 adjustable upper control arms were used for the swap to adjust camber.
pre-DA swap:
post-DA swap:
    It puller yer caster back should drive easier straight.... adjustable traction bar could fix it if it bothers you.
    naw, it doesn't bother me at all. I don't even notice any difference to be honest. i posted it more for information sake than anything. sometimes there is a lot of debate about DA stuff up front. This should help put an end to that.
    Your camber kit doesn't rub inside while cars on the floor? I had this problem but didn't use skunk kit.
    Im agree ive ran prolly 3 EF's with integra front knuckles and they all lines up no issue. I dont see the hype on trying to find the super rare EX hibs.
    cars on the floor? rub where? i get no rubbing what so ever.
    I am running DA6 knuckles and if lowered everything lines up perfectly. You need camber correction to do it properly.
    I have the same issues with caster but I suspect that is something related to the front sub frame.
