searched but didn't find. Stock RT spring rates?
Anyone know what the stock spring rates are for the 88 RT? I'm looking at upgrading my suspension for my daily. I've been through the suspension opinion thread and will be taking it into consideration. Just looking for a baseline. I'm leaning towards progress suspension and will add my thoughts on it to the suspension thoughts thread if I go that route. If you could provide the link that would be awesome too (I'm sure it's here somewhere, just not finding it atm).
I just put OEM ITR springs (250f - 140/250r progressive) on Koni Yellows and the front is about 1" lower on the lowest pirch and the rear is .5" lower on the middle pirch. it could be lowered another .75" to the lower pirch.
Suspension setups are completely relative to how you use your car, what your roads are like, and weather conditions.
where i live... if half of you guys even considered driving up here between november and march, you would have another thing coming. Hence why i chose what i did. For the money i spent I could have bought something else with a crap adjustable ride height, but i wanted quality and good RIDE QUALITY. The Koni Yellow / ITR spring & top hats, imo, is how the suspension should have been from the factory, pleasing to most drivers, but a touch on the stiff side for some.
http://www.civicwagon.com/showthread.php?16304-Koni-Yellows-amp-OEM-ITR-Springs&highlight=koni
side note: adding the rear swaybar will make almost as big a difference as any suspension setup you put on. i just did it last week. Do yourself a favor and may as well get some godspeed or whatever rear LCA's with the threaded holes and new bushings. i've had mine a year and no issues at all. virtually as cheap as just doing oem bushings but a lot easier.
