4WD Diff questions
I was just wondering if anyone knew what the life span of the OEM diffs were. Are there 3 or just 2? How often is the rear engaged? From what I read, these are mainly just FWD cars until driving gets a little more agressive, or conditions change. The RealTime system. Does it kick in when the inside wheels slip? ... or the outside wheels grip? I need to research that one somemore. Since Honda came out with the RT system in the new Acura RL, I wonder if there will be any swapable components. What about from the AWD CRV? I know there are none, but I wonder how the RTi Wagon would react to a fixed (locked) or Phantom grip diff(s)? Just curious. I'd hate to screw up an already good system. Just looking for more grip and drivability.
Ken
Ken
Thats the RT4WD pretty much explained.
Theres three diffs... the front diff (front wheels) centre coupler and rear diff.
Lifetime is the same as any other provided you maintain it properly. If you thrash it then you run the risk of breaking stuff, the same as any car.
Theres one or two members who have locked the system up..
As for the CRV (97-01), it seems to have a very similar undertray and component setup, to the point where most stuff looks like it will bolt up.
Negative on that one, but making a bracket for it wont be all that difficult.
Oh Yenpit, where for art thou?
If it does bolt up and you want to lift your wagon it looks to be ideal.
