ZC Boost & ECU
Sup guys, I just finished my ZC DOHC M/T swap into my 90 2wd wagon last weekend. I LOVE the difference in power and fun to drive factor . My old D15 A/T was a slug. I was wondering if anyone has boosted a DOHC ZC. I looked around but everyone is Boosting SOHC D16's, Also what harness mods are required to change to obd 1? I think I am using a re-flashed PM-6, but on the decal it looks like someone purposely scratched the PM-_ then sharpeed ZC ECU over the #'s. Car runs great just confused if obd 1 will pnp. I have a PM-6, will that run a DOHC engine? I already moded the harness at the ECU for the DPFI to MPFI and also the cam pos. sensor, will this change work with other ECU,s?
i think i was asking $100 for it.
Greenville isnt too for actually, well.. maybe a little haha its like what, 3 or 4 hours from Savannah?
A friend of a friend is now running it in his track car and gained about 1 second with it. It also backfires now when there is a quick transition from throttle to brakes (aka all the time on the track).
In the UK ours are not chipable so we take the ECU from a similar car called the Rover which has two versions. The one with CAT is chipable with one without is not. These are called PP4 or PP5 but essentially identical to the PM7 as the Rover uses the Honda engine.
The JDM PM7 CRX Si ECU is chipable. It also runs a CAT.
The UK CRX does not run a CAT.
Se the similarities ?
I can't speak 100% for the Euro ECU's but I'm pretty sure that they are the same.
But, with CAT = chipable. No CAT = not chipable.
IIRC a USDM PM6 (a chipable one, again I think you have two versions?)will run the code from a JDM PM7, or certainly you can copy the fuel & ign maps across with turboedit etc.
Hell I plan to run a D16A6 on a PW0 ECu whichwas designed for a B161engine. It makes no difference if you can create the map to make it run correctly.
If you look at open Turboedit then I'd suggest a PM7 or in the UK a PP4 and run the NG60 code to make your life easier. BRE can also edit NG60 code, but it works better with PW0 and I'm more used to that ECU hence my use of it.
BRE rocks.
JDM Speedcut = 180KM/h
EDM Speedcut = 222KM/h
:P
I don't even know if the wagons can get to 222km/h on stock power/weight/aerodynamics.
Speed cut easily removed in mapping software anywho.
Get it, chip it, done.
