Have any of you built your stock motor ?
Like the title says ... Has anyone built up there stock motor or just swapped something else in ? If so, what mods have you done ?
  • Lots of people have built stock motors in civics (but not necessarily wagons). Check out d-series.org for more info. I'm currently building a high compression motor for my 4wd wagon.
    ive got a fully built A6 in my CRX i havent ran it yet but its in there....
  • mvmmvm Wagonist
    Just curious, I am also building an A6 and was curious what you have done to it and where you got your parts from ?
  • ludesrvludesrv Band Wagon
    http://www.exospeed.com
    Pretty good parts for the cash. Use PM7 Honda pistons from a DOHC ZC for a boost in compression without spending serious cash. You can find them for cheap.
  • Also check out bisimoto.com, he seems to know his stuff and has excellent customer service from what I can tell. He'd rather know your setup and grind a slightly different cam for it than sell you a off the shelf stage cam.
  • mvmmvm Wagonist
    So has anyone built anything that they can talk about ?
  • Well, in the next month or two I might be able to talk. I have a set of p29s that I got with a motor (this motor will later be used in my hatch with a turbo) and I have a d16a6 block. I'm claying a y8 head tonight and probably an a6 head on the a6 block. If I can't mill either of the heads enough to give me the compression I want then I shall rebuild the a6 block completely and put the p29s in.
    Speaking of my spare block, it has 196k miles and still has visible crosshatch. :shock: :P :shock:
    my d16a6 has
    9:0 to 1 pistons
    eagle rods
    headstuds
    balanced
    blue printed
    isky valve train
    cometic headgasket
    delta cam
    cam gear
    skunk2 IM
    LS integra TB
    DSM 450cc injectors
    and the turbo kit i had on my wagon this summer
  • ZLITESZLITES New Wagonist
    turbo_teg wrote:
    my d16a6 has
    9:0 to 1 pistons
    eagle rods
    headstuds
    balanced
    blue printed
    isky valve train
    cometic headgasket
    delta cam
    cam gear
    skunk2 IM
    LS integra TB
    DSM 450cc injectors
    with all those mods, how much HP are you pulling?
    its not quite finished. im not shooting for big numbers its my autocross car so the turbo is quite small.
  • more tq. than hp, and a TD04!!!!
    i might upgrad to a hybrid t3/t4 i think it will still spool good for me and still be able to make decent numbers. i kinda want to take the head off and put a vtec head onto it but thats just more money.
  • turbo_teg wrote:
    my d16a6 has
    skunk2 IM
    Just how much bigger is that over the stock item ?
    I've got a D16Z6 one but have seen a few people pushing these or modding the stock item for a bigger plenum.
    For the B series there isn't that much to be gained going from a B16 to an ITR one. But the D series one is rather tiny in comparison so I guess it's worthwhile ?
