Stock wagon height specs?
Looking for stock height measurements on both two wheels and RT Wagons 88-91.
Anyone with stock suspension, if you could take a measurement between the center of your wheel hub and your fender lip on flat ground both front and rear, it would be a big help!
PS: Only take your height measurements from the hub to the lip, as anything else takes in tire pressure ground clearance etc etc.
Thanks!
Thanks!
Front - 15" on both sides
Left Rear - 15 and 3/8"
Right Rear - 15 and 5/8"
Hope that helps ya.
So just to be clear, this measurement is from the center of the wheel hub to the fender lip on each corner, correct?
I was installing my KW coilovers, and because I made some changes to the springs, I wanted to see what I was below stock height on my 88RT. Unfortunately when I purchased the car it had a pretty nasty spring setup on it.
Thanks again!
I wanted this lower than stock. Maybe Im getting old or somthing, but slamming a vehicle with 4wd just dosent appeal to me. I want this thing to be a good snow and winter vehicle! So I only was looking for an inch or so. This mesurment helps ALOT. Thanks!
Check it out for sure. There is a lot of "this will get you this" floating around, but I havent seen much in the way of actual mesurments. Im still not totally happy with mine. I LOVE the height its at, but becouse I had to use a longer springs to get it, I am runing into binding issues.
I am going to try a shorter spring in the front and a perch this next time around. Ill see if I can get a picture and some mesurments for everone soon.
Thanks again for the good info Eldonciv!
So I should either get coilovers and put them on with my illuminas, or heavier springs.....I'm thinking coilovers.
88RT4wd
90-93 integra springs
90-93 integra struts
91 si CRX rear LCA's with poly bushings
fronts
15 3/8" maybe even 15 1/2" too close to call
rears
17"
that is on flat level ground without me in the car. i dont know if the crx lca's with poly bushings would make a difference i just wanted to be specific.
