Radio Wiring Which Color goes to what?!!
Can someone confirm the radio wiring colors for me.
I am trying to install a radio but do not have a diagram to go off.
Any help greatly appreciated!
http://lmgtfy.com/?q=ef+civic+radio+wiring
I have Googled it before I was hoping for confirmation from someone that the colors are correct.
Radio Constant 12V+ Wire: White/Blue
Radio Switched Ignition 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Turn On Wire: N/A
Front Speaker Size: N/A
Front Speaker Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speaker Size: N/A
Rear Speaker Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Adapter?
The factory wires were cut.
If I got an adapter I would still need to do the same thing wire in the factory wires to the adapter so why not just go factory wires straight to radio and save a step?
