Step by step Intructions.
I've been searching and haven't found anything very helpful on how to remove the axles on a RT4WD up to removing the tank.
I saw Bams comment on how to remove gas tank but nothing that really helped me out. (sorry Bam)
So does anyone have a Step by Step write up on removing the axles, driveshaft, and gas tank for new people with a RT. I've never dealt with anything like this set up.
i think you'll have to remove the whole rear diff to drop the tank, that's why the hole for access.
Un bolt Rear LCAs from RTA, pull shafts out of diff.
Unbolt UJ on driveshaft.
Unbolt diff
It's actually fairly easy as long as your wagon isn't really thick undercoated haha.
Without taking out axles and LCA's on a rt4wd.
So all I did was jack it up as high as I could and through jackstands under it.
Took the 4 bolts around the diff off (12 point 10mm wrench or socket)
dropped that down.
Unbolted the 2 17mm bolts from the bracket on the diff.
Unclamped all the fuel hoses and from the fuel pump.
Removed the fuel pump. (from under the seat)
dropped the exhaust
Then unbolt the 2 long 14mm bolts that hold up the diff.
slowly drop the diff (I used a jack)
Now remove the 2 tank straps (12mm) and it should just drop right down.
Hopefully that helps you. I'm not very good at wording stuff haha.
Yes I had plenty of room. It was a lot easier honestly
I cleaned my tank with Acetone. You can find a gallon of it at Home Depot for under $15.
I poured that in my tank and swooshed it all around for about 5 minutes (drain it out) and then filled it with water and did the same thing. You really only need to do it once but I did it once but I did it twice to make sure all the pine needles and dirt got out in the tank.
I went on ebay and found on that looked just like the one I need for the rt4wd but when it came in the mail it was a crx one... I emailed the company and they haven't responded. I really can't find a rt4wd gas tank anywhere. Try to find one from a junkyard if possible.
For the autozone straps and hardware I really don't know. I'd assume it would be fine. Buy it and if it doesn't work then bring it back.
Well guess what... Just popped a damn hole in my tank. I was cleaning off some exterior rust and BOOM started leaking. Luckily I found a tank and im hoping its in good condition!
Damn. that sucks... Well best of luck.
