1991 RT4WD Problem
I was thinking on trading in or selling this wagon but I thought I might see if someone has an solution to my problem. I thought based on the sound that the problem was my right CV axle......I replaced the CV axle but that did not solve the noise. After switching the switch on the tranny to 2WD the noise is gone. That said the wagon runs in both 2WD & 4WD but the sound must be the result of problem. It sounds similar to a CV axle that needs replaced and depending on how much torque you apply while driving increases or decreases the noise. I aaume this is 4wd related as the sound is gone while in 2WD. Could this be a bearing in the transmission? This is way out of my knowledge and was hoping someone may have an answer for me. After all I just had custom built u joints on my 3rd prop shaft put on for $400 in August, I would hate to lose the 4WD capability now....
Cheers
Cheers
Mine had a hole in it after the brg inside exploded.Didn't find much of the brg left.
rattle, humm, vibrations?
Cheers!
http://www.hondacivicwagon.com/board/vi ... php?t=2767
It's part #159(about 1/3 way down on the last column )on the parts list.The photo is the 2nd pic.It's the cvr just to the upper left of where you bolt the center axle to.It has 5 bolts on it.3 are covered in oil.You can bearly see the ribs. My quess is it's about ready to do a aliens thing.
