New battery and alternator - still not charging 91 rt-awd
My battery light came on while driving home from work. The headlights were getting dim and the wipers slowed so I changed the alternator. The next day the battery went dead so I bought a new one and now that's going dead. The battery cables were green and dirty so I cleaned them up with sandpaper and all other wires seem to be ok. Anyone have a guess where i should look next? I'm working with limited tools and no voltage meter :disturbed:
I saw this on another civic forum but not too familiar with the wires he's talking about. "Well after long hours, changing the alternator again and a new battery, I finally figured it out!!!! The was a loose wire in the big wire harness that comes from where the ECU is. The wire was black and yellow"
Any help or suggestions would be greatly appreciated.
Steve
Steve
I took a peek at fuses just to see, thanks darktrickster. CURRENT PROJECT: 1988 rt4wd Civic Wagon - gotta love those rt4wds
Oh, and might want to make sure that your engine is properly grounded (the negative battery cable will route to the chassis under the battery tray then to the tranny somewhere).
