if you ever thought about sportmax wheels
Well I bought some sportmax wheels 16x8 with the 0 offset and decided to see just how far they would stick out.
I found some metal flares here that just might work to get these on. The wheel wells rust out here so replacement wheel arches can be had for just about any car. I was thinking about a little more wide body look seeing as my wheel arches are getting some rust.
Here is some pics for you.
The wheel arches I found are way more aggressive and should bring it pretty close to the edge of the lip. A little negative camber might just get these to fit.
This is a project for next summer maybe but this is to give some ideas for you guys.
Q, wouldnt the front rub at the slightest turn and bump on the road?
I just wanted to see what they would look like on the car since these things were just sitting here. They were originally for my new VW wagon but they stuck out even farther on that thing
If I can pull off this wide ass fender flare and throw a little negative offset on there it might not look too bad. I am a little worried about the fronts rubbing during turns. I will have to mount them up front to see what it will take. I will take more pics this weekend.
hopefully I will be able to start this soon.
the sportmaxes will have to wait. will a normal tire place have any trouble putting narrow tires on the rims? they like to BS me over here so im just wondering...
you know what that means then? find another shop lol
