Pull up your passenger side carpet and take a look at the small glass window atop the ECU. There is a red LED that will "blink" the corresponding # representing the system indicated. Turn your ignition to the ON position, count the flashes.
alright let me see if i got these codes straight it will flash once stop then flashes 10 times stop 1 flash stop then 14 flashes stop and repeats it self.
Does the one flash mean any thing in between the longer flashes?
http://ef-honda.com/ben/ECUcodes.php
Or is it just a starting point for real codes?
HELP!!!
give me a call
