cavity filling with water behind rear wheels
I changed my taillight assembly out last night with one that wasn't cracked. I thought that might be the reason the cavity under the little tray in the rear cargo area was filled with water. I got all the water out and was expecting it to be dry this morning. Wrong. So I checked the other side, it was filled with water as well. I'll post pictures when I get home, but wanted to throw this up there in case anyone has had to deal with this in the past. There isn't much water in the area for the spare tire, just on each side.
Any help would be awesome, foggy windows are not tight
Taillight gaskets and also the seam @ top of the D pillar where the rear hatch hinges are (can crack) would be good first places to check. Prior owner, of mine, stated same issue. After I painted my car I never had any problems as I resealed the taillight gaskets and those tiny hairline cracks at the corner/hinge area. The rain is def coming down here but I haven't had any issues (yet).
Please do report back, most folks seldom do.
