I have a bad td43u dizzy. Can I swap the guts from any other Dizzy into it to make it right? I was guessing a D15B non vtec dizzy but cant find anything to confirm that.
Ring your local car parts store that would sell the sensors and see if the part number is the same. This should tell you if you can swap between them (or if you have both already compare the two)
To my understanding, the internals on a dizzy are the same for all the "OBD"
So all obd0 parts are interchangeable with other obd0 dizzy parts. I have tons of ignitors, coils and rotors all from different dizzys and have never had an issue with any of it. The dizzy I used for my 90 wagon with a 91 b18a1 was out of a obd0 accord and had misc. obd0 in it. Hope this helps.
The ignition coil?
TDC sensor?
CYP sensor?
