Bruce, I'm new here, and I have no clue, but you're probably going to need to post more details. Like if CEL is on, have you checked your ECU for any codes, does it eventually start again, etc.
Yes it starts again perfectly fine. Check engine light come on randomly on really hot days. The engine temp is perfectly fine. Never over heats. Didn't check ecu yet. I read around and suposley the throttle body is dirty and trapped carbon is in the air filter tube connected to the throttle body. Or my fuel injectors are dirty. Any more info needed rb26240z?
When I was stalling for no particular reason, I changed my distributor, and so far it's been running without stalling...
