random electrical feedback
every so often when i hit the brakes it triggers the parking lights to come on
does not do it all the time just once and a while
lighting mods
third brake light flasher module
all bulbs swapped out for LED
tested
disconnected third brake flasher module
checked some of the rear bulbs for feedback
any ideas or theories you happen to have let me know
thanks
  • i have a 1987 isuzu pup that used to do that. one of the light sockets was corroded, and when you hit the brakes it would jump between the two filaments on the bulb. i would check that the sockets are all nice and clean. there isnt a single filament bulb put in where a double filament is supposed to go, is there? that would also make the parking lights come on, but i think it would happen more often.
  • i thought about with me swapping out for LEDs and all the soldering thats going on there if it might be an issue
    got them from a good company and the bulbs where still drop shipped from china :(
    ill just put the brake buddy on and start pulling bulbs and see what happens
