what do you guys use to clean REALLY dirty wheels?
So I picked up these RT steelies recently, for $50. I think I did fairly well on that deal... :-)
They look great from afar, but up close, they are fairly dirty and stained, and have some scratches in them.
This is the worst one. (after I cleaned the hell out of it)
What do you guys recommend to clean this up a bit? I obviously would like to save the paint if possible, but it's starting to flake off on the center caps, around the holes for the lugs.
Thanks!
Thanks!
Brand: Zep Commercial
Disc: Industrial Purple Cleaner & Degreaser concentrate
Note: Dilute to desired strength but dont use on anodized metal as product may discolor depending how long you leave it on the item.
This sounds like it will eat through the paint, no?
I have a big ass bottle of Purple Power. Is this stuff similar? I was thinking of diluting that and seeing what happened, but I figured I would ask first...
x2 ive made some rt wheels come back from the dead with this stuff (consentrated)
I have two sets (plus a few extras) of the hubcap-style lugs. one set off my del Sol, and one set that was on my 4 door when I bought it. I am really hoping they are the same ones that the RT uses. But yeah, I thought about that and I knew i had a few different ones to choose from. Thanks for the heads up though. If for some reason they are different than other hubcap style lugs, let me know. All the ones I have are like normal lugs but they have like a plastic ring near the base that's supposed to hold the cap on...
