ej8 j32a2/3 frankenbeast!!! pic intense...
so its coming down to the last few weeks of my build... its been a very long time in the making since i have a budget i must stick too.. here are some pics... i started with an automatic j32a2 auto from an 02 tl type s... its the cable driven and not the dbw (drive by wire)... so it requires a tad less technology to get it up and runnning and tuned... then i came into a deal. my buddy hooked me up with a j32a3 assembled shortblock and as you can see the domes are much higher than the j32a2. and so since the j32a3 is a drive by wire motor i used the j32a3 internals (crankshaft, pistons, domes, with brand new oem bearings) in my j32a2 block with the stock type s heads. now my concern is my compression may be a bit higher than i had anticipated so no shaving heads or getting the j32a2 (03 cl-s cams which are the only true manual cams in the cable driven (99-03) motors)... here are more pics for you guys
on the cc's of the combustion chamber of the heads if i new that i can figure out that question
the base model j32a1 (99-03 tl/cl cable driven motors) run a 9.5:1 c/r, the type-s model j32a2 (99-03 cable driven motors) run a 10.5:1 c/r, and the j32a3 in the 04 model (dbw drive by wire) run an 11:1 c/r
so according to my very handy source and guide up in new york who has been doing j swaps for about 2 years now says i should be looking somewhere around 12:1 which is higher than i planned but will be amazingly fun.
yes im looking into that or a toulene/premium mix or c16 race gas or maybe the new pure gas if that will do the trick... we just got a pure gas station here in jax,fl...
