toggle menu
civicwagon.com
civicwagon.com
Sign In
Register
Sign In
Register
Sign In
Register
Home
Electronics, Fueling & Air Conditioning
Auto awd with z6
Freek
Wagonist
March 2012
in
Ok guys got everything minor fixed on this now time to convert to obd1 which p28 should I use being auto? Thanks
DRMORTY
Council Member
March 2012
It doesn't matter.. The AWD has a stand alone tranny control module (TCM)..
It's not built into the ECU. So, you can use any Manual ECU..
Standard P28 is fine, if your using a Z6
Freek
Wagonist
March 2012
Sweet thanks man
Sign In
or
Register
to comment.
